Welcome to Android Central! It'd help to get more details about the problem, and also to know what you've tried. Is this the stock messaging app? Are you getting notification icons in the status bar, just without any audible tone? Is your Ringtone/Notification volume slider turned up? Are the Notification settings in both the System Settings and in the Messaging app's settings correct?
