A Android Central Question Aug 2, 2018 #1 Why is my Alcatel a30 losing charge when it's on the charger I'm super confused and worried please help
methodman89 Well-known member Feb 5, 2018 4,141 295 83 Visit site Aug 2, 2018 #2 First, make sure you are using a good charger and cable. Next open settings and go to battery, look at usage. See what is drawing it down. Upvote 0 Downvote
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Aug 3, 2018 #3 The phone is probably using more current than it's designed to draw from the charger, so the net "charge" is negative - discharge. Use Ampere to see what it's using when the charger isn't plugged in, then what's happening when it's plugged in. Upvote 0 Downvote
