A
Android Central Question
I have an Android Samsung S7 Edge . I recently had 13 gigs of mobile data used in one day. When I went under mobile data used, it showd that Google "Photos" used all the data. And my battery is draining 10% every 20 minutes. When I go under "device maintenance", then click on "storage", then "clean now", I see this Chinese writing but I can only assume is a virus. After hitting "clean now" my battery returns to normal and doesn't run out quickly until I either reboot the phone or turn on Mobile or Wi-Fi data then this virus seems to start back up again. I've tried multiple malware and virus skins and nothing is being detected. Anybody have this issue or can help me with this? Thank you so much!
