A
Android Central Question
Just today after not using my phone for a couple hours, it's just a black screen. Holding down power does nothing but after about 2 seconds cause a very thin white line to flicker near the top of the screen. Holding Volume down + Power to soft reset also does not work and produces the same result. Is there something else I can try or do i have to bring this in and get told they can't replace it?
Note, i have NOT ever dropped it and the whole phone is spotless and has had no problems in the past. I have only had this phone for a couple months.
