A
Android Central Question
I was using my phone and it ran down and died and then I put it to charge for a while and then I tried turning it on and it wont turn on. Instead a blue light comes in on the indicator
Can you go into recovery?I was using my phone and it ran down and died and then I put it to charge for a while and then I tried turning it on and it wont turn on. Instead a blue light comes in on the indicator
