My fingerprint sensor stops but after I put my code in the phone to unlock It I don't have problem
  • Start date Start date
A
Android Central Question
This has happened before fingerprint works after putting code in. Once again "hacked"?
Welcome to Android Central! Which phone? Most Android phones will periodically ask you for your PIN or pattern, even if the fingerprint sensor is working normally -- this is for increased security.
Hey bro! Can you describe your situation in more detail in order to give you the right diagnosis?: D
Has this incident occurred one or more times? Did you wash your hands before picking up the phone? So many questions and so few answers ... I hope you clarify your question because it will be very difficult to help you!
It won't be difficult as we have all the info we need. In this case the phone is a ting normal by wanting periodic password confirmation even when fingerprint security is in use. It is nothing to do with washing hands. Thanks for your contribution
I mentioned the situation with handwashing because there were so many situations due to the fact that finger scanner does not work effectively with dirty hands. If the problem revolves around a periodic password, then try to go into your device’s settings and check your security settings. Maybe the problem is there! I hope I helped you :)
There is no problem, this is normal behaviour
There's a screen timeout and a lockscreen time. After the screen times out, but before the lockscreen comes on, you can use your fingerprint. Once the lockscreen comes on, you have to use the secondary (PIN, Password) unlock. Set the screen timeout (normally not longer than 30 seconds - it's the timeout after the last time you did anything), then set the lockscreen timer for a longer time (maybe 1-5 minutes).
Or use Proximity Service and put the phone down face down. That turns off the screen and stops the lockscreen timer. (So you save battery, you prevent burn-in, but the phone doesn't lock. You can set it to lock when you tap the power button, so when you go out you can lock it quickly.)
Flykxd133
