Zenwatch battery replacement?
rogueofthesea
zenwatch battery replacement
Has anybody tried to replace the battery on the asus zenwatch? Is there an upgraded battery available? What kind of duration SHOULD I be getting from a charge? Is it the same battery as the samsung? They look to be of similar shape and construction.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! By the end of the day, my ZenWatch battery is down to around 50%--and this is with the screen set to Always On, with brightness to 4. Every now and then, it drains more quickly, which I can't figure out--I wonder if it's due to problems with Bluetooth signal. If you're having rapid battery drain, try uninstalling all of the apps, or do a factory reset, and see if it persists.
AmeliaRodriguez
