Battery symbol with question mark inside!
lesnmor80
So I didn't put my Bionic on the charger when i went to bed last night and now it is fully dead and when plugging into charger the battery symbol shows up on middle of the screen with a question mark inside. I have pulled battery several times and it will not power on even after leaving it on charger for at least 1 hour. What do I do?
KillerG
1,156
71
Hmmm check the terminals? A question mark battery usually isn't good, your battery might be screwed. Try plugging it in and waiting for a full charge...?
LDubs
645
34
28
Also can try a different charger if you have one, maybe your charger somehow got fried. It should have immediately begin charging and should have been able to power it up within probably 15-20 mins.
corymcnutt
615
37
I got that with a BB I had...they told me it was the battery, but when they put a new one in...nothing. It ended up the phone was fried...funny thing; Verizon wanted $40 for a new battery and only $50 for a new phone to replace my 16 month old one, so I made out with a new phone/battery for only $50.
highbar81
14
Last time I saw this was with my OG Droid. Reset the phone and it never came back, it was fried. Take it in and have them look at it.
wth123
This happened to my bionic. I opened the battery compartment and inspected one the leads on the battery itself. It seems like one of the leads wasnt coming out enough to make contact with the phone leads. I got a thumbtack and bent the battery lead out and it worked.
Santiago Molina
Hi,
I googled this problem and got here. I just wanted to let you know that my problem was a faulty usb cable. I got to the office, switched cables and the phone started charging right away.
Thanks!
Santiago
Mengl09
I Have this problem with my phone every couple months. The phone always fixes itself within a few days.. I have read so many threads on it, and people replace so many different things and say it fixes it.. But then others would try it and it wouldn't work. I just keep it plugged in And within a day or so it's working again.,I mine also will not charge, and just says 0% charging forever. I have also noticed with this phone I go through charges every two weeks. My friend has the same phone as me, which is a hauweii from straight talk and it does the exact same thing. But my battery gets that question mark symbol, and it a,ways works again.
Dwayne Jackson1
Re: Movable parts inside my LGG3 D850 phone
Hello Guys.
I had purchased an LGG3 D850 ,but i have noticed when i remove the battery that the area below the battery(Black area) is movable.I want to know if that is a normal thing. When i shift that area i able to see the screen from inside.
acieus
This may sound completely nuts, but as I was about to give up on fixing my wife's phone with this problem, she looks at me and says "I've had the happen before! You just blow in the bottom by the USB (jack) and it comes back to life!"
To my astonishment, she did it right in front of me and the problem was resolved. Go figure. Thought I'd share.
coolgamer_28
3
Tried and it doesn't work.
