BSOD: Possible Solution??!!
rduckwor
Active member
Jul 25, 2011
40
4
Those of you having constant BSOD issues, here's a potential solution.
Power off your handset, remove the back and remove the SIM card (not the SD card but the 4GLTE SIM card). Clean the contacts with a soft cloth and reinsert the card firmly into it's slot.
Close it up and power on.
There have been anecdotal reports of loose and mis-seated SIM cards causing this issue.
Not 100% certain, but I reseated mine weeks ago (9/21 to be exact) and have not had another BSOD.
Good Luck,
RMD
ab07
