tsitalon1
Active member
Donations sent!
Everyone please do the same if you haven't already. People like these guys are what makes Android so great!
ThanksDonations sent!
Is anyone else noticing battery leaks? trying to isolate the problem it averages 1 percent or so every 30 min it looks...
Only had the phone 2 days but yes, I seem to be losing more battery than I should.
"Display" is my highest listed item, but still something else may be chewing it up. Maybe it's time to install spare parts.
Mine seems worse than that.
4hrs unplugged, on 38mins of "Display" using something like 70% battery with media server being second item listed only using 10% battery for 20mins. Battery was at 83%.
Can't be the display...I hope not. 38mins of display at lowest brightness setting can't possibly chew 15% or so battery can it?
Signal is 3-4bars constant
Please don't misunderstand, I am not blaming the Rom, Hell I've only owned the phone 2 days so I can't even compare to the stock Rom. LMAO.
No i understand you dont blame the rom. It could be the kernel but i doubt it. what is media server, are you streaming something?
signal includeds your data so if you are in a patchy 3g/4g area the hand off between them could be sucking you dry,
Thanks
so at 1% every half hour, thats 2% every hour so it takes 10 hours to drop 20% i can live with that leak lol
I put SetCPU on my phone and it seems to have significantly helped my battery life. Was draining pretty quick, now it goes an entire day without needing a charge. Also keep my screen brightness at 1% inside and 50% outside. The auto feature off and also the power saver feature off.
I'm using SetCPU also and it seems to have helped alot. Curious tho you using Profiles at all and if so what settings do you use. And also curious if you have used or set the Advanced tab in setCPU.
@DroidxCon did you happen to see my post back a page or so about My Verizon Mobile. not a biggei just curious is all
I love the ROM and there will be a donation heading your way this afternoon. I was hoping that you could post the daily briefing app. I tried pulling "infoalarm.apk" out of the ED1 system dump, but moving it in to system/app, but it didn't work. I know that I can't add the widgets to launcher pro, but I was hopeful that I could at least open the app and see the information. Thanks!
Hey all been a long-time lurker both here and xda, my question today is one I cant seem to find the answer on....I've had HTC phones my whole life so when ROM updates came out I'd toss it on my SD card boot into CWM wipe and install, but with Samsung I learned that method does not work as things need to be flashed through ODIN under PDA, now my question is since this recently got updated...do I just install it the same way I installed the first version? Do I need to wipe any data from the phone b4 doing the ODIN update? or just mirror my first process with the updated file? Thanks!
Haven't used the advanced tab. I have had SetCPU installed for about 3 days now and I have had 1 random reboot in that time. That could be because of my screen off settings? Not sure, it hasn't worried me since it's only happened once, so I've just left it as is.
Opeth: Install it the exact same way you installed the first time. I went from v3 to v4 using the exact same method for each,
I'll second the carbon fiber needs to go, and flat black would make it allot easier to read.
Thanks everyone for your hard work. If you have not donated please do.
