[INFO]INDEX
Post #1=CWM basics
Post #2=What is Voodoo
Post #3=How to Voodoo
Post #4=How to unVoodoo
Post #5=Troubleshooting Voodoo
Post #6=How to tell if Voodoo is enabled
[/INFO]
[INFO]Download the newest recovery from imnuts.[/INFO]
Make sure you thank imnuts for all his hard in making CWM fully functional.(its not done yet, but it will be cause he's awsome and he likes banana's)
Clock Work MOD or CWM, is a recovery replacement for the Samsung Android Phones. In CWM you can create back up’s of ROM’s, restore to a previous back up, format data, clear cache, wipe dalvick cache, wipe battery stats and more. I will explain the basics for now and into more depth later.
Now most of that is self-explanatory, so we won’t dwell too much on each right now.
[NOTE]Use the menu key as the back button.[/NOTE]
Creating a system back up is the first thing you should learn to do, and the first thing you should do before screwing with your phone. I don’t back up every time I install something new. What I do is set my phone up just how I want it. Then I back that up. This is my working back up. If I screw up my phone at least I can get through the day until I have time to flash a new ROM. The system back up is just the ROM; it does not back up the radio or the kernel. It creates an image of your system.
Post #1=CWM basics
[/INFO]
Booting to CWM.
1. With the phone powered off, hold down the vol up, Home button and the power button all at the same time.
2. When you see the “Samsung” logo, let go of the power button.
3. After a few seconds you will see a screen that has red writing and a few lines of text, that is CWM.
CWM Menu
-reboot system now
-apply update from sdcard
-wipe data/factory reset
-wipe cache partition
-install zip from sdcard
-backup and restore
-mounts and storage
-advanced
-voodoo
-power off
Backing up your ROM.
1. Using the volume down key move the high light to “backup and restore”
2. Use the power key to select
3. Use power key to select to select backup
This part can take several minutes, so be patient.
Installing A New ROM or Theme or whatever
1. Using the volume down key move the high light to “install zip from sdcard”
3. Move down to choose zip from sdcard
4. Use power key to select
5. Navigate to the folder and file you want to flash
6. Select with power key
7. Now you will see this:
–no
–no
–no
–no
–no
–no
–yes
–no
–no
–no
8. Arrow down to yes
9. Select with power button
Once you are done, use the menu button to back up to the home screen and select reboot system.
