ETPhoneHomeT
My phone is still running as good as it did when it was brand new, with only rare occasional periods of laggy performance. Some things I do:
- Reboot (power off/on) the phone every few days
- Perform a cache partition wipe through the recovery menu at least once a week
- I only use the stock browser which I find to be much faster than Chrome
- I use 3rd party launchers, with the smoothest and fastest being Nova Launcher Prime
- I have 2 apps that I run every once in awhile called "1-Touch Cleaner" and "Fast Reboot"
- I've always performed at least one FDR on all of my Android phones whenever I've taken an OS update
To identify if the lag is caused by a rogue app, you could try running your phone in Safe Mode. In Safe Mode, if the lag disappears, then you'll know you have a misbehaving app.
From what I understand, beginning with Android 4.3, TRIM support has been added and should reduce or eliminate lag in the Android OS
