Case to fit extended battery?
thrillhouse847
Active member
Sep 13, 2010
31
I'm sorry if this question had ben addressed already but I searched and couldn't find an answer. Does anyone know of a case out there, our soon to be perhaps, which would fit a Fascinate with the extended battery? I am already missing out on using the dock (imperfectly designed as it may be) because of my big battery, I don't want to miss out on a case also...
You can disregard this question, after installing the battery I think it's probably just too big to use so I won't need a case like this after all.
KB3MMX
387
6
There should be factory cases for those with factory extended batteries, that seems to be a big problem for those who want a extended battery but there's no accessories that properly fit..
jophsie
I have a Samsung Epic with keyboard. I also have an extended battery. Im looking for a case that will fit so my phone will be protected. Will the bodyglove silicone cases fit and if not could I use the case without the battery cover. Does anyone has any other suggestions.
