- Jan 16, 2023
- 1
- 0
- 0
I have an elite T8 plus given to me by the sky tablet manufactures and mobile data service with a phone number.
How can I make it work like a phone?
So there is a way you can use your tablet as a phone. You won't be able to use the number on your tablet but your not using it no so shouldn't be a big deal anyway. What you can do is download a free phone app from the GOOGLE PLAY STORE. The most popular one I probably TEXTNOW. Or GOOGLE VOICE works also. I've done it on the Sunshine T1 Elite (8 inch tablet) and I've done it on the tablet I have now which is the SkyPad 8. I used GOOGLE VOICE this time. It will give you options for surrounding city free numbers. DO NOT TRY AND PORT the number on the phone # on your tablet. Won't work unless you wanna pay and deal with who ever services your tablet. Just read every page and follow instructions. You will verify the number Google Voice gives you with your phone. Have to verify. No biggie though. I can make and receive calls and text now. And voicemail. If you don't like it then it's as easy as deleting the app and try TEXTNOW or a different app. A different FREE APP. There's plenty. Those 2 apps have the best ratings and reviews. Any questions let me know. Have a great day.I have an elite T8 plus given to me by the sky tablet manufactures and mobile data service with a phone number.
services
Also it isn't mobile data service. If you open SETTINGS then open ABOUT PHONE info then SIM STATUS. This is what I'm guessing it says.I have an elite T8 plus given to me by the sky tablet manufactures and mobile data service with a phone number.
But what if it doesn't say that? What if my sky 8 says this instead:
