1. shelbie27's Avatar
    I just bought a Lg Genesis Saturday and this is my first android so I was looking around on it then I clicked "root" now my phone will only turn on to the start up screen & if I am lucky sometimes turn completely on for a few seconds then shut off again. What can I do to fix it or can I?
    02-15-2012 11:08 AM
  2. baseballfanz's Avatar
    What method or tool did you use?
    You have to give a little more infos than that of you need help
    02-15-2012 03:05 PM
  3. pazzo02's Avatar
    From how you describe it, there was somewhere on your phone where you clicked to root it. Sorry, but rooting doesn't work that way. I know you can't get you're phone working now, but you need to explain exactly where and what you clicked. Maybe you can go back to the store and look at a display model to find it. Just a thought.
    02-15-2012 08:05 PM
  4. applesarekool's Avatar
    Hold the home key and the power key at the same time. Same thing happened to me once. I'm more bricked than you are now. I deleted a system app and now I cant get it back! >.<
    02-26-2012 11:42 AM
  5. applesarekool's Avatar
    Worst comes to worse, hold volume down, home, then power at the same time to factory reset.
    02-26-2012 11:43 AM
