I have the nexus s 4 g. Every times I Bluetooth with another phone it says "paired but not connected ". How can I get connected? I cant seem to get past this hurdle. Please advise.
If you go into Bluetooth settings and tap the device you're trying to connect with it should connect. Some devices won't connect automatically like you would think. I have to do this every time with my bluetooth speakers.
Same, I have to manually connect many devices. If Pazz's advice doesn't work, sometimes a reboot of whatever devices you are trying to connect can help fix the problem. I've had it where when I tap the device to connect, that it'll connect and immediately disconnect. Usually a reboot will fix it though.
