I recently bought a Note to try out ST. It's been great so far.
What I'd like to know is why the Speed Test app works sometimes for mobile data and sometimes it doesn't.
I'd like to do some tests before deciding if I want to stick with Sprint or completely swap to ST.
It always works on wifi.
FYI, when it has worked I've had dl speeds over 5mbps compared to the 100kbps I get with Sprint.
Anyone know why it doesn't always work?
Sent from my GT-N7000 using Android Central Forums
