Heya guys, this is my first post so, go easy
I've hunted through the vast pages of knowledge that come up from Google.com for the past 2 hours on this, and searched this forum but to no avail - I can't find anyone else that's had a problem like this! :c
So, this is the story.
I cabled my Samsung Galaxy Ace to my computer, and copied over 3 music files - something I've done countless times. However, this time when I removed the device, the microSD Card became corrupt. After an hour or so of searching, I found a solution and fixed the card without having to format etc. However, when I tried re-adding the files (As they didn't save) after the fix, I would disconnect my phone from the computer, and find that the files hadn't actually saved onto the microSD Card. Confused, I re-connected my phone and tried it again, and double-checked that the files had copied. After disconnecting my phone, I'd found out that the files still didn't appear on my directory. I reconnected my phone, backed up all the contents of my microSD Card, and began to format the microSD while it was in the phone via Windows, as trying to delete files on the phone resulted in them reappearing after the phone did a media scan on the card. I didn't do a quick format (As I tried one 5 minutes before and the entire microSD Card contents reappeared even though the SD Card had 0% of the space used according to the computer. About three-quarters of the way through formatting, I got an error saying "Windows cannot complete the format". Now, my phone says the SD Card is blank or has an unsupported file-system. I've taken it out of my phone and found a microSD-to-SD card adapter. But my laptop won't read it.
So my question is, have I ruined my SD Card? Is there anyway to save it? I'd prefer to go to the lengths to fix it myself, however I'm not willing to pay to get it fixed. And if there is a way to save it, how? It can't be read by my Samsung, my old Nokia, or my laptop. My information is backed-up so if push comes to shove I will purchase a new one. But like I said, if there is a way to fix it, I'd like to know.
Thanks!
Thanks!
