Macro button's on desktop and that stupid bluetooth/google now issue?
X-Nemesis
99
1. Is there an app that will let you put an icon on your home screen and then assign a macro to it to perform a set of instructions when you click it?
2. I'm suffering from the issue that is using google now voice search, on a Galaxy S3 when bluetooth is turned on. It simply doesn't work when you press the voice button to speak your command, it just sits there and then finally times out. I searched online and found a video that said that if you turn on the "touch sounds" that it will eliminate that problem but I'm still having the same issue. Has anyone found a fix for this at all?
NK01UK
