Gencc
Golfdriver97 hi .can you help me with my s4 gt-i9505 afer updating to 4.4 my wifi wont turn on and my gestures are not working have you any idea how cean repair this sorry for my english.
Samsung updates.com has a library of stock ROMs.
Look for your EXACT model number, and download it.
You will need a program called Odin. Download and install that.
Look over this: [Guide][Samsung] How to flash Stock ROM via ODIN - Android Forums at AndroidCentral.com
And ask any questions before starting.
From a Sprint Moto X using AC forums app
Can be removed. Amazing what happens when you put a couple of geniuses to work on a problem and give them a couple of months.It is Samsung's version of security software. Can't be removed, disabled, etc.
I recently updated my Galaxy S4 to Android 4.3; the update went 100% fine, no issues, no errors, nothing. After the apparently perfect install, I turn it on to find out WiFi WON'T turn on. The WiFi setting stays on "off" no matter how many times I click on it. I tried putting it in Airplane mode, but that didn't do anything either. I tried restoring to Factory Settings and that didn't work, either. I can't set anything up because it doesn't let me even turn WiFi on and I don't have signal because I purchased the phone unlocked. Please help me out! I have no clue what's going on. This never happened before on 4.2.2 and now I can't even use the phone. HELP!
I'm experiencing the same issue except it's a little worse. I can't make calls, and I have no sound (can't even play through headphones, no alerts, etc.). I went to Samsung-updates.com and was only able to secure the 4.3 ROM. I have the exact same t-mobile S4 (M919). Any help would be immensely appreciated. Thanks!
Go on wifi and you'll see a thing called smart mode, click on that smart mode, it'll ask u whether to turn it off or on, you want to turn it off. I just found out today
