I have noticed that my phone gets so slow it is practically unresponsive often. I strongly believe that the culprit is high I/O. Using an app I can often show that the storage is at or near 100% utilized when my phone gets slow. Sometimes it is from high reads (around 12-15 MB/s), and others it is maxing out on writes (around 3-4 MB/s). At this same time, my utility shows that my CPU usage is usually well below 50%.
My phone is running MoKee 4.4.2, but I have had the same issue with CM running ICS and Jelly Bean.
My questions are
#1 Is there any way to monitor what apps are reading and writing to storage? My device is rooted, and I use Linux on my desktop if that helps.
#2 Do you know of any common culprits for this issue?
#3 Any other ideas?
My questions are
#3 Any other ideas?
