Where is the 4g option on my Note 3?
marselisgn3
74
to be clear. my country doesnt yet support 4g. so no 4g sim card. but id be happier to have the 4g option there. when on settings-more networks-mobile networks-network mode all i get is 3g/2g autoconnect, 3g only,2g only. i want my 4g / lte options to be there even tho they wouldnt work.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Re: no 4g option on my note 3
I would guess it has to do with your SIM card. If the network doesn't have 4G, then its SIM won't give that as an option.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It depends on the note 3 variant that you have. Some variants are 3g only. If you want a 4GLTE capable Note 3, then you may have to buy one from another area . keep in mind the region lock issue too, it would have to be used on its origin region first. Also, make sure whatever you get has full support for the bands used in your area
Sent from my Verizon Samsung Galaxy Note 3
cloudsofmana
