How do I fix: Unfortunately, the process android.process.media has stopped?
ABDUL LATIF SHAIKH
How to Fix: Unfortunately, the process android.process.media has stopped
I have encrypted my phone and unable to access media. Please help...
i got same problem. The problem cause by micro SD or storage can read/write the file media. To solve this problem, u must change the setting storage to the internal storage or change the Micro SD card. or format back ..or format again the sd card by using exFAT file system.
shawnjosecrespo
