How to make my mobile save on internal memory and not on sdcard?
ProCro17
3
So hi, i have zte blade g and i have 1.5Gb internal memory. I had sd card 2Gb and it broke. After that i couldnt take any pictures or download from internet anything. So can anyone help me somehow. I wanted to somehow make my mobile save everything on this internal memory but i dont know how. When i want to take pictures it sayes that i dont have SdCard and in settings i can choose for directory where it is going to be saved but when i choose internal it does nothing. Thanks
Welcome to Android Central! Does your Camera app have a setting to select default storage location? Open the Camera, tap the Menu button, and look in its settings.
I assume you've also checked the System Settings for a default storage or download option?
I have selected default storage to be internal in camer menu but it keeps asking me to insert sdcard. I can not find in system settings for that..
I also want to say that i have terminal emulator installed and if someone knows how can i do it with that program i would be thankfull
How well do you know Linux? Can you mash fstab to make it think that the internal storage is the external card? Or make a symlink so either sd0 or sd1 point to internal storage? (Or maybe mount sd0 on the root of sd1? I don't know if that would work.)
I dont know to work in Linux. If there is any way that this requirement for sdcard can be removed it would be awesome. I just dont get it why do i need sdcard when i have 1.5Gb intern memory.
Foxy
