Triple tap on keyboard activates zoom.
According to the accessibility gesture description triple click/tap should not activate the zoom on the keyboard, but it does anyway.
This is annoying when when I hit enter or erase repeatedly, and I do that quite often.
The only way I have found to deal with this is to tap slower when I erase, but that's not really feasible.
Is there a way to solve this? I need to be able to type without triggering the zoom.
Thanks
Thanks
