How can I adjust the vibration level on my LG Volt?
A
AC Question
how can i adjust the vibration level on my lg volt?
I just set up ny lg volt, and cant find where in settings to change the vibration level for my keypad and menu/back buttons. Its too strong at the moment.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Re: how can i adjust the vibration level on my lg volt?
Welcome to Android Central! If you can't find a setting for that in the System Settings, then you can't adjust it. This kind of adjustment is pretty uncommon in Android devices.
Non
