My Intex is showing on screen your phone Android has stopped, how can I fix this?
  • Start date Start date
A
AC Question
my phne intex showing on screen u r phne android is stopped plzz tell me solution
My mobile intex phn showing u r phne android as been stopped so plzz give me a solution for this... N tyrd by doing reboot device bt also it's not working plzz tell me solution
Re: my phne intex showing on screen u r phne android is stopped plzz tell me solution
Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
RangelS25
