HI , i am using Samsung Grand Prime . From the past few hours my i have this problem that my phone is charging but not showing the charging sign. And i have to restart to check the current battery status. but once the wire is unplugged, then again it is stuck there and i have to restart again to check the status.
Plus ,
My Mobile is rooted and i have
1) unrooted the mobile
2) reset it to factory settings.
3) Wipe the phone cache
4) install a new firmware through Odin,
But problem is still there.
Any help??
Plus ,
Any help??
