A
AC Question
what just happened to my phone's LCD and storage ? Backlight?
Earlier today, I noticed that instead of a black screen, the LCD has become low lit grey when my phone goes to sleep! I also noticed that all of a sudden, my SD card started "misbehaving". The app Google Play Music and my phone's Gallery only showed the music and image files saved on the internal memory. And yet, my VLC player had ALL media files, including those on my micro SD card. So I had to check my SD card by clicking File Manager. In Quick View, my files saved on my SDc could not be found. However, there was the EXTERNAL MEMORY option; all my stuff was on it and read. So, what I did was reboot the phone.
When it turned on again, there was a notification that my SD card was safe to remove, even though I DID NOT unmount it! So I mounted it again, and waited a few minutes to see if my files would be loaded. Unfortunately, the same issues persisted after several times of rebooting, mounting and
unmounting, and re-inserting my micro SD card. I also made sure that the problem's not with my micro SD, so I inserted it to my cousin's LG. Hallelujiah, it worked just fine.
Now, every time I turn off and on my phone, "SD card is safe to remove" always pops up. Also, I tried uninstalling my recent apps to no avail.
