So I am trying to make a theme for the myTouch 4G that will show up in the Personalize section for the themes. I downloaded the source of a theme from github and loaded it into Eclipse. I modified the androidmanifest.xml so it would say the name I want instead of what it had, "Androidian." So I loaded the apk onto my phone and installed it no problem. Then when I went to apply the theme in the settings though, I got continuous FC's and it wouldn't load the theme. I had to do a nand restore. Can anyone help me fix my apk so that it wont do this and so it'll load correctly? Thanks.
