Predictive text and spacebar problems?
caloundra15
predictive text and spacebar problems?
In my Google subject window between each word requires two spacebar taps. Secondly, predictive text does not work in the sense when I try to forward emails I select a contact and the next contact has part of the earlier contact name in it and I have to erase and then second time it works. Help, please. KB
Re: predictive text and spacebar problems?
Hello..
Could you provide a little more information as to which device and/or Android version your using? Also are you using the stock keyboard or have you added a 3rd party keyboard software?
yanis
