Sharing webpages - issue with sharing directly to phone contacts
So after the latest Android update...when i try to share a webpage or to others, the result is a little different than before...
It now has a top part that shows contacts so you can directly share to them instead of choosing the app and then the contact within that. So the problem is that it doesnt show the contact faces every time, just their phone numbers. Then when i try it again, it sometimes pulls in the faces of the contacts. So it is inconsistent and that is not a fun experience. This needs some work here. It isnt working properly. So the share function needs to be examined and fixed. Shouldve been tested thoroughly before release.
My phone is HTC one m8.
