- Dec 12, 2017
- 3
- 0
- 0
Guys, I have been uploading video to instagram for ages until yesterday. I had to format the sd card and now when trying to upload video i get this message "before recording videos check your sd card and disconnect your phone from computer"
If it helps, the thumbnails have disappeared from the camera, so when you go to look at the images just taken nothing shows up just.
I have tried un-istalling then re-installing Instagram but nothing. Should I do a factory reset?
TIA
TIA
