Used com.ressor.swing is what it says on my dashboard .. I don't Kno what it is or how I "used" it .. is there anybody out there that can explain to me what this is
Hi dear: Better ignore or review again the Domain: com.ressor.swing
it should appears as : ressor.swing.com - I tested with "Virus total
as "com.ressor.swing" Virus total is a Google site
that test Domains-URL's-IP's Etc,.
it cames up with this explanation..See screenshot : Wait I took the
screenshot on my cellular. I'll try to posted in a mins :: Here's..
Sorry turn your phone in a Horizontal position to view the screenshot..I'll try to post the screenshot, OoPs! where is the attactment
on last line is that <com.ressor.swing> is not a
valid domain pattern, so that's all my help
Did you enter "com.ressor.swing" in the URL field on the Virus Total site? It's not a domain name or URL -- it's a system level app (like com.google.android.gms.setup). In order to use Virus Total for that app, you'd have to extract it somehow and upload it to the Virus Total site.
Right, but what I meant was that "com.ressor.swing" isn't a URL -- it's the name of a system app.
