It used to be the case that if I type a word that Gboard doesn't recognize (and thus it appears undrlined), I can then press on the word and an "add to dictionary" option appears together with other spelling suggestions. Now this option doesn't appear anymore, and I can add words only through the dictionary menu in Gboard settings. Is there a way of re-enabling the option to directly add words from the keyboard? Thanks!
I am using Samsung Galaxy s8 with Android version 8.0.0 and my Gboard app is updated to the latest version.
