minix
I use different router and my problem is solve.
Hard reset and factory reset did not solve my problem
My N7 is WiFi only.
If you are referring to my GNex you seem to be missing the point. I'm not talking about the minute it changes over. I'm talking about it never connects. If you don't have the problem you can't understand but it's similar to how your home router might lose connection to the internet but you are still connected to the router except that in this case the router is fine. Or you are on 3g or 4g then get home have it switch over to WiFi and half an hour later when you finish changing clothes, all your apps tell you you don't have a signal even though it looks like you do but really nothing is happening.
Sent from my Nexus 7 using AC Forums mobile app
I Solve my home wifi problem recently its something to to do on IP address, change DHCP to static on nexus wifi setting.]
Settings -> Wi-Fi -> long-press on your SSID -> Modify network -> select the 'Show advanced options' checkbox -> change 'IP settings' from DHCP to Static.How do you get to that option?
I've had this same problem since I upgraded to 4.4.3... When through all the suggestions on this thread without any luck. Finally, tracked the problem to Juice Defender... Seems like a compatibility issue. Once I disable Juice Defender, the problem of the Wi-Fi not automatically connecting back to network upon Nexus waking up from sleep is gone. I figure you should check any battery saving application which controls the Wi-Fi and disable it to resolve the issue.
Settings -> Wi-Fi -> long-press the SSID of your router -> Edit -> check the 'Advanced settings' checkbox -> change the DHCP setting to Static IP and then enter the IP address that you want to use.Gnr2: How do you do the switch with the static IP?
Thanks for the detailed explanation. I'll need to check all of this myself. My N 7 works great now, but my GNex now has the same issues.Settings -> Wi-Fi -> long-press the SSID of your router -> Edit -> check the 'Advanced settings' checkbox -> change the DHCP setting to Static IP and then enter the IP address that you want to use.
Be sure it's on the same subnet as the rest of your devices (usually 192.168.0.xxx) with a subnet mask of 255.255.255.0 if it prompts for one.
And of course, don't use an IP address already in use by a different device on your network.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
I have a SERIOUS problem. The same problem in fact. The suggestions that suggested things like toggling Airplane mode didn't help.
I was on either 4.2 something or 4.3. I had put off installing any updates for some time. For precisely this reason. There are only so many ulcers I can stand.
I felt lucky yesterday, and installed the most recent updates I had. I am on 4.4.3, and not yet approved for 4.4.4. I'm on a 2013 Nexus, but I also have a 2012.
Soon (less than an hour) after installing the updates, the Wi-Fi died.
It SAYS it is connected, but nothing can be done. No surfing, Google Play, etc
It behaves as if it is not connected.
I thought it might be the Wi-Fi, but another Android device worked just fine. So it IS the tablet. I will call Google Help again tonight, but I already tried wiping the cache, and that helped the temporary power drain I developed yesterday afternoon (while it slept for 7 hours, it lost 17%). Wiping the cache did nothing for the Wi-Fi problem.
Facing the same issue. My eight month old Nexus 7 was working fine till a month ago but now connecting to wifi is a major issue. It is showing connected but data flow is zero. Toggled airplane mode etc and tried several tips given here but no use. Now trying a factory reset as last recourse.
I'd also noticed that even when tab was connecting to wifi, the connection was v poor when physically further away from router. Though I don't face this with my laptop or Android phone. What could be the reason?
Long story: http://en.m.wikipedia.org/wiki/Dynamic_Host_Configuration_ProtocolI don't even know what DCHP is but for some reason KitKat doesn't like it.
