xorbe
I don't think nandroid backed up everything ... wasn't there a row about the wifi partition not backed up after the 4G key was corrupted?
What is the App you are running in the first post to show the historical performance data?
Thanks!
Ok, here's a question for the EE types out there (which I am not).
If you have a processor running at 1ghz and it completes a task in 1 second and then you underclock it to 250mhz and it completes the task in 4 seconds have you saved any power? I'm not sure if the power consumption curve is linear or not. I seem to recall way back in my brain that it is linear which would make me think that you would just be breaking even in the above scenario. I'm sure that there are a bunch of other factors that I have not taken into consideration here (like system overhead processing) but I'm just interested to figure out why the underclocking seems to work from a technical perspective. Can anyone shed any light on this?
I'm using the Incredible... and it all seems to work great... of course, I have no idea what I'm doing - so thanks to PPM for his great and simple guidance.
However, am I supposed to set the main screen max back to 998 after I have set the profiles, enabled the profiles and disabled the perflock?
From what i've seen, the main tab just seems to reflect whatever profile the system has currently made active. So changing the main tab wont do anything.
I'm running damage control, what would my best setcpu settings be?
Question for the OP..
Are you still getting what you consider better battery like with SetCPU after you updated to Froyo? Also, do you still run that Task Killer? Isn't it possible your improved battery life is due to the TK?
A better control would be to remove the TK, then to try the handset with/without SetCPU.
My experience is that SetCPU makes like or no difference to Froyo's sucky battery life. Froyo is noticeably worse than 2.1, at least for me.
Read the thread for your ROM over on XDA. I'm not sure but I think damage control has a lot of tweaks for battery life already built in. That being said, if the kernel that installs with that ROM has perflock disabled already and it doesn't have value already built in you would benefit from these setting in setCPU.
I have noticed a gain in battery life with these settings. It also has a lot to do with the ROM you run. I'm running the AC ROM which has other things done to improve battery life. When developing the ROM the devs made sure that they weren't gonna have bad battery life. My girlfriends EVO is not rooted and has no tweaks done to it or anything to improve battery life. She has the Froyo OTA on her phone and gets great battery life. Some FROYO ROMs go for performance more than battery life so depending on which one you're running that might be the reason why.
Hi, let me start by admitting I am new to this, but dont the screen shots show a serious flaw for proof that this actually works. I mean the top pic shows crappy battery service yes, but thats from the hours of like 12 noon till what 5pm? with a corresponding high amount of useage at the time period. The bottom pic after using set cpu is from the hours of 12 am till some thing like 6 am, yes the batter discharge is very good however, there was no use occuring, at all, durring corresponding time. It looks to me as if the pictures show what one would expect, if you dont use the phone, you don't discahrge it as much as you would if you were actually using the phone.
