I'm in the process of routing my 2.2 evo. I'm running on a macbook pro right now but i'm running windows 7 via bootcamp. At first i downloaded all my files while i was using osx and then i copied them over to my c:\ BOOTCAMP partition and set up all the files and put them where they need to be ex. c:\android\tools\xxxxxxx.zip now i plugged in my evo and went to go transfer unrevoked to the sdcard in the command prompt and its not allowing me saying failed to copy permission denied. it didn't work so i redid all the downloading the files set up another directory all while on windows and i'm getting the same error. Can any one help me out with this?
