So I have been using version 2.3 and it had no problems with it. The problem I ran into yesterday is that none of my nandroids will work. I even made a backup that day and it wouldn't work.
The only things that I backup is boot, system, data and wimax.
When I try to restore it starts for literary a sec and then says:
oops... something went wrong!
please check the recovery log!
Now correct me if I'm wrong, but to check it I just go to other and move recovery.log to SD?
If so then I tried that and I get the same response when trying to restore the backup.
Now the things I have tried:
Re-installed through my bootloader with the PC36IMG. Same result
Flashed clockworkmod and then tried to re-install amon through rom manager. same result.
So, anyone know what is going on or a solution?
