This.If all the phones functions work correctly including the speaker and microphone, then you probably got away with it. Does it not say in your user manual what the hole is for? It's an unusual place for it to be the speaker.
Apparently it's a microphone.
On fixit I found a tech guy that disassembled the mate 20 pro.
It seems that the microphone cannot be reached from the hole since it sits on top of a little motherboard and is also protected by a gasket the is perpendicular to the hole. So, it seems that the pin only reaches the plastic of the mid frame.
Hi,
I just bought my new mate 20 pro and i love it.
But the problem is - when I've tried to take out the sim tray using the sim pin, that was in the phone's box, i accidentally poked the speaker hole, which is about a centimeter away from the sim hole.
Did i cause any damage to the speaker?
ThanksView attachment 294838
Hi,
