First, GPS has nothing to do with Wifi.
Second, if the building construction is such that you're getting multipath distortion (a signal reflecting off something, so it appears to be two signals, or the signal your phone is seeing is the reflected one, making the path a nanosecond or two longer), your phone's GPS may not be as good at rejecting multipath distortion as your sister's phone. Different software in different GPS receivers are susceptible to different things.
So unless you need GPS to find your way around your house (that was a joke), as long as the GPS is accurate outside, I wouldn't worry about it, unless I was planning on using it in a large city with nothing but large (50 floors or more) buildings, or in a dense forest. GPS is nominally accurate to 10 meters (32.8 feet), so if it's 32 feet off, it's working normally, it's just at the edge of its accuracy.
Install
GPS Status & Toolbox, run it and, when it gets a fix, look at the HDOP (horizontal dilution of precision - the middle number in DOP/HDOP/VDOP; that's a measure of how accurate the GPS is at the moment in the horizontal plane). The lower the number, the better, but if it's close to 10, it's still within the system's specs. (In my house it happens to be 1.0 at the moment, but there's almost no wind [that can affect it], the sun has been up all day [a change in temperature outdoors affects it], the house is made of wood and is only 1 floor, and there's nothing above - as far as the GPS is concerned, it's outdoors. I've had situations in large, "lots of steel" buildings, in which the GPS couldn't get a signal at all.)
(GPS is totally separate from cellphone, WiFi, mobile data - it's a 1.5GHz [approximately] signal coming from the GPS satellites. It's very weak. And location is calculated by the differences in the time it takes the signals from each satellite to arrive at the receiver - down to 2 or 3 nanoseconds. So it's like a city balanced on a pin - anything can throw the accuracy off. The great thing isn't how accurate it can get, it's that it can work at all - from a tiny satellite to a small cellphone. Back in the 50s, you'd need a 10 foot tall antenna and a few feet of 6 foot tall cabinets to contain the equipment needed to not even come close to what's in your phone as just one little part of it. Oh, and at least one technician at each cabinet to keep the system balanced constantly. That
is kind of miraculous, isn't it?)
