What case do I need to charge my LG G2 with a wireless charger pad?
  • Start date Start date
A
AC Question
What case do i need to charge my lg g2 with a wireless charger pad
i have a European lg g2 and I know it doesn't support wireless charging out of the box but heard there was a case made by lg that made it capable but I cant seem to find what it is, is it the quick window case or a different one
Re: What case do i need to charge my lg g2 with a wireless charger pad
If you don't have a Verizon LG G2 then you won't have it built in, what you can do is find one of the thin wireless charging pads that plugs into the microUSB port and have it sit between any case and the phone when properly aligned.
I cannot speak to the quality of this product http://www.amazon.com/BLUBOON-Unive...ag=hawk-future-20&ascsubtag=UUacUvbUpU4668162 but I found it on Amazon.com and it seems tob e universal. Worse case you return it to Amazon as defective if it doesn't work.
LEricG
