Bastian Lindemann
so my fix to this issue (LG G7) was: I pressed a toothpic wich I thinned out so it would fit in the charging port against the faced down side of the port so the side wich is down when you phone is lying on something and I very gentilly pressed the inner plate up a bit (coincidetially found this) and I found out that the usb (original) cable was resposible for this because i think I broke it a while ago by deforming the inner connection in the head of the cable
edit: just fixed the issue temorarily for about an hour
