Lg g5 camera problems
  • Start date Start date
A
AC Question
My lg g5 camera after upgrading to android 7 is realy bad in low light. Pictures are very dark,even wide angle lens photos look brighter. In good light conditions pictures are fine,just the low light sucks. Looks like aparature now is not f1.8 but f2.8. Has anyone experienced the same??
Using Dropbox.com or Google Drive or the like, link us to an unedited, not resized example so that we can see what you are seeing.
That complete dark picture is from main camera,another one where you can see a bit is wide angle camera which is f2.4
Interesting that both have a shutter speed of 1/9 second.
The darker one has an ISO of 400, the other has 0.
What happens if you try a manual exposure?
yes bro... I have the same problem after upgrade... and it's not the aperture... 'cause it's on 1.8... but the camera firmware doesn't seem to allow the sensor to use iso higher than 400 anymore!!!
Can anyone help???
Can anyone help???
So do I. Camera did a really bad job at a friend's open mic.
jocar37
