Is anyone having problems with the headphone jack on the G6? I noticed some problems early on, but hoped it was just bad timing with an "old" aux cable and an old pair of earbuds, but I've replaced each and it seems to be getting worse.
I have a short 1' aux cable (2 pole) with two 90-degree ends that I use to plug into my car stereo. Just touching it when it is plugged in causes it to crackle, pause/play the track, and skip. Same result with an older cable and a brand new one I just got from Amazon. Just to verify it's not the cable, I just tried my old Droid Turbo and it is flawless. I can wiggle and spin the plug and absolutely nothing happens.
I also have a couple pairs of earbuds (3 pole) with inline mic. The old cheaper pair worked ok at first, but now cause the volume to spontaneously raise and lower, and keep pulling up Assistant. Same earbuds work fine in the Turbo. I have a newer pair of earbuds, also with an inline mic, that work fine in the G6.
I've ruled out it's obviously not the cables or earbuds if they work fine in the Droid Turbo, but still one pair of earbuds work fine in the G6... strange. Just wondering if anybody else has issues? I'm thinking of contacting LG, but I hate the idea of sending it in and probably getting a refurbished phone...
