Hi,
I have recently bought a LG Optimus Elite (I know it's out of date, but it fits my budget) and am extremely satisfied with its performance. One problem I am having though is that I only get 1.5-2 days of batter life, which I think is normal for this phone. I rarely turn on WIFI, and if so, only for a cummulative 30 min. a day, bluetooth, gps, and sync (including background syncing) are always off and brightness is all the way as dim as possible. I also periodically go through the manage apps settings each day and force stop on apps that continue to pop up running ( I only downloaded 2 apps btw). My problem is that whenever I check my batter stats (Settings--->About Phone------>battery graph), the blue bar for "Awake" time is still painting about 50% of the batter life, even though every possible source I can think of that would wake up my phone is shut off. Any solutions to the problem?
Thanks,
Jeffrey
Thanks,
Jeffrey
