Can this method be used for unrooting VC?
I am on VC stock, rooted but still having problems when I power my phone off. When I power up, I get stuck on the LG logo, then have to pull my battery, remove my sd card, and either power up or enter custom recovery to reboot. Upon rebooting, I can then insert my sd card and all appears to work well. I'm considering reverting back to V8/V9 to see if that will fix my "power up problem". If that fixes my problem, I'll then root and install custom recovery.
Does anybody has any insight into whether unrooting VC and going back to V8/V9 might fix my power up problem? And can anyone confirm that this unrooting procedure works for VC? Thanks in advance.
