cordell
Pretty much the same here, 4% then FAIL
10:58:23 : ********* CDMA Model.dll input Parameter End*************
10:58:24 : wParam : 20, lParam = 570
10:58:24 : MODEL DLL Event : (20, 570)
10:58:25 : Model Dll Msg Not Found(20, 570)
It seems like the tool it constantly dropping and restarting the USB connection, as the This device can run faster on high speed USB port keeps popping up, along with the USB connect/disconnect sounds.
If we disconnect data cable and remove battery, the connect data cable only the download screen does not come up on phone. A screen comes on saying "BATTERY REQUIRED".
I dont doubt that this works, as I seen the phone connecting to the tool yesterday in emergency mode, I just didnt know what to do with it, lol. That where the pro's take the reigns and compile a fix Maybe a "High Speed" USB port is required, I miss my laptop
Perhaps since the radio never flashed it needs to be V9 for me?
