[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
Re: [How-to] Revert to LS670V9, after installing OTA LS670VC/VD,
Yes, I enjoy GB but want the ability to stream WiFi, I have flashed ROM's on many Windows Phones and my previous NS4G but the Optimus S seems much more involved. Would it be better to chat via google or another way to not clog up the boards? Thanks
I'm doing that now, hopefully I can get it up and running correctly, once I do would you be able to help me in this thread? http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/119130-how-rooting-ls670zvh-40.html
Currently unpacking files, saying phone will automatically be reset after update, from there whats the next step? Sorry
After the "download" stage, which is really just uncompressing the files it will do the update. At around 98% the phone should reboot. Then the android screen should appear. Do not disconnect the usb cable until you see "update complete" in the status window on the lg update tool.
I was keeping it on the boards that way if others see it and can help they will know where you at. Plus it is almost 11pm here, so I will be going to bed shortly. To be honest I would avoid GB as many people (myself included) have had issues with it, which is why Sprint has suspended the GB update. For the time being I would just flash to whatever version you are flashing to with the K500 tool and then root it using z4root or gingerbreak.
Alright LG S/W Update says has been complete phone still plugged in, and is asking for an email address for future updates, no option in cmd to press Q to exit and phone is off while still plugged in
Thanks Infinity for the late night help
Nevermind, I went back and saw you were able to boot into Android but were getting FCs.
What you want to do is
Factory reset from stock recovery
Do you see errors in the log or does it look complete.
When you say the phone is off while still plugged in, that seems out of the ordinary. It should have rebooted. Are you sure it isn't "on" but you don't have anything show on your screen?
Did you revert to V9 or VD and do you know if you have the new LCD?
Tried reverting to V9 from ZVH, realized i had a new LCD, used this method to get up to ZVD but it hangs at the Sprint logo... adb shell returns an error "exec 'system/bin/sh' failed: No such file or directory (2)"
Help!!!
The error about /system/bin/sh is normal. Don't worry about that.
Try this:
Factory reset from within Stock Recovery
I did notice on your other post it seems like you started doing a lot of stuff and possibly could have made things worse. I'm not sure what state you are in right now. You did ZV9, then ZVD, then ZVC, then ZVH.
ok im about to cry:'( I updated to zvh so i followed this post to the . on the i and now my screen is blank...but i am at zv9 what do i do HELP!!!!!
ok so now i am back at zvd, but once i get the sprint logo it gets stuck on the android screen. what do i do?
My suggestion is when you encounter a problem you don't know how to deal with, ask questions before you proceed, to avoid making things worse.
In your situation, as long as you can get to the Android logo, a simple reset should resolve:
Can anyone provide the VD cab so i can sideload using LG updater?
The links provided seem to be broken. Thanks.
"Substitute these steps to Force Flash VD
f) download VD cab (LS670ZVD_12.SD_12.P60675.cab) (Alternate download)
h) ren LS670ZVD_12.SD_12.P60675.cab LS670ZVD.cab
i) expected checksum - 6bd5faf21acb951abb7e2c6e8ce39e7d *LS670ZVD.cab
n) cab file - LS670ZVD.cab
o) version - LS670ZVD_12"
There's something wrong on your side. Both links work fine for me.
Reactions: QikPass
Seems that for some reason this was inaccessible via Cablevision's DNS servers, I had been trying for 2 days, 3 different computers, no luck.
Changed DNS to google's (8.8.8.8 / 8.8.4.4) and access was granted.
Is there a mobile support tool I can use with my mac?
No. You can try emulator, but it may be some work to get everything working. If you just need to revert to VD, then you can use the ZVD update.zip in my signature. That doesn't require the mobile update tool.
Any Ideas
08:09:19 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
08:09:19 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
08:09:19 : Start Date : 2011-10-26 08:09:19
08:09:19 : -------- Buyer Test mode ---------
08:09:19 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
08:09:19 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
08:09:19 : *****CheckOS Start********
08:09:19 : Microsoft_Windows_Vista Professional_
08:09:19 : *****CheckPCSyncPrograms Start*****
08:09:19 : PCSyncPrograms Not Found
08:09:19 : SetEmerModeAT()
08:09:19 : _IsConnectedPhone Call
08:09:25 : _IsConnectedPhone(1)
08:09:25 : 0 - NotConnected.
08:09:25 : 1 - Normal connect success
08:09:25 : 2 - Emergency connect success
08:09:30 : Checking the connection with the cell phone...
08:09:30 : dwWaitResetTime(40000 ms)
08:09:31 : Phone Mode(1)
08:09:31 : *****GetPhoneType Start*****
08:09:33 : Phone Type : CDMA
08:09:33 : *****Start GetPreviousStep*****
08:09:33 : _GetPreviousStep(dwStep:0xffff)
08:09:33 : _SetPhoneNumber retval=1
08:09:33 : *****GetPhoneModel Start*****
08:09:35 : *****GetPhoneBinaryVersion Start*****
08:09:35 : Phone Bin Version : LS670ZVH_00
08:09:35 : *****Get ESN / IMEI / MEID Start*****
08:09:38 : ESN/IMEI/MEID : A0000028CD0047
08:09:38 : *****GetPhoneNumber Start*****
08:09:40 : Phone Number : A0000028CD0047
08:09:41 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028CD0047, Model :
08:09:41 : *******CheckBinVersion***************
08:09:41 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVH_00)
08:09:41 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
08:09:43 : _GetAuthMark : wAuthMark(3369)
08:09:43 : Wait 3Sec
08:09:49 : _SetAuthMark Ok : wAuthMark(3369), PhoneMode(1)
08:09:49 : *****Start _GetBatteryLevel*****
08:09:52 : Battery(5)
08:09:53 : ResetPhone...
08:09:53 : Checking the connection with the cell phone...
08:09:53 : dwWaitResetTime(40000 ms)
08:10:23 : _IsConnectedPhone Call
08:10:29 : _IsConnectedPhone(1)
08:10:29 : 0 - NotConnected.
08:10:29 : 1 - Normal connect success
08:10:29 : 2 - Emergency connect success
08:10:29 : Phone Mode(1)
08:10:29 : m_dwBootWaitTime(35532)
08:10:29 : Checking the connection with the cell phone...
08:10:29 : dwWaitResetTime(30000 ms)
08:10:59 : _IsConnectedPhone Call
08:11:04 : _IsConnectedPhone(1)
08:11:04 : 0 - NotConnected.
08:11:04 : 1 - Normal connect success
08:11:04 : 2 - Emergency connect success
08:11:04 : Phone Mode(1)
08:11:04 : Call _ModeOffline()
08:11:05 : *****CheckPCSyncPrograms Start*****
08:11:06 : PCSyncPrograms Not Found
08:11:07 : CLGMobileHttp Class ?Ҹ????.
08:11:07 : CLGMobileHttp Class ?Ҹ?...
08:11:07 : ****************CheckAndDownload********************
08:11:07 : ******Extract Start LS670ZV9.cab*****
08:11:07 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
08:11:07 : ExtractInfo Error(0)
08:11:07 : Extract cab file error.
08:11:07 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
08:11:07 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
08:11:07 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
08:11:07 : Page_Error ?κ??Դϴ?
08:11:07 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
A little help I am stuck at the android splash screen for optirom
system will not boot after reverting to v9 is factory reset a smart thing to do
Thanks
STUCK!!!!!!!!!!!
Code:
13:54:22 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
13:54:22 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
13:54:22 : Start Date : 2011-10-31 13:54:22
13:54:22 : -------- Buyer Test mode ---------
13:54:22 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
13:54:22 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
13:54:22 : *****CheckOS Start********
13:54:22 : Microsoft_Windows_Vista Professional_
13:54:22 : *****CheckPCSyncPrograms Start*****
13:54:22 : PCSyncPrograms Not Found
13:54:22 : SetEmerModeAT()
13:54:22 : _IsConnectedPhone Call
13:54:28 : _IsConnectedPhone(1)
13:54:28 : 0 - NotConnected.
13:54:28 : 1 - Normal connect success
13:54:28 : 2 - Emergency connect success
13:54:53 : Checking the connection with the cell phone...
13:54:53 : dwWaitResetTime(40000 ms)
13:54:54 : Phone Mode(1)
13:54:54 : *****GetPhoneType Start*****
13:54:56 : Phone Type : CDMA
13:54:56 : *****Start GetPreviousStep*****
13:54:56 : _GetPreviousStep(dwStep:0xffff)
13:54:56 : _SetPhoneNumber retval=1
13:54:56 : *****GetPhoneModel Start*****
13:54:58 : *****GetPhoneBinaryVersion Start*****
13:54:58 : Phone Bin Version : LS670ZVD_12
13:54:58 : *****Get ESN / IMEI / MEID Start*****
13:55:01 : ESN/IMEI/MEID : A0000028C8375C
13:55:01 : *****GetPhoneNumber Start*****
13:55:03 : Phone Number : A0000028C8375C
13:55:04 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028C8375C, Model :
13:55:04 : *******CheckBinVersion***************
13:55:04 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVD_12)
13:55:04 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
13:55:07 : _GetAuthMark : wAuthMark(27234)
13:55:07 : Wait 3Sec
13:55:12 : _SetAuthMark Ok : wAuthMark(27234), PhoneMode(1)
13:55:12 : *****Start _GetBatteryLevel*****
13:55:15 : Battery(5)
13:55:16 : ResetPhone...
13:55:16 : Checking the connection with the cell phone...
13:55:16 : dwWaitResetTime(40000 ms)
13:55:46 : _IsConnectedPhone Call
13:55:52 : _IsConnectedPhone(1)
13:55:52 : 0 - NotConnected.
13:55:52 : 1 - Normal connect success
13:55:52 : 2 - Emergency connect success
13:55:52 : Phone Mode(1)
13:55:52 : m_dwBootWaitTime(35608)
13:55:52 : Checking the connection with the cell phone...
13:55:52 : dwWaitResetTime(30000 ms)
13:56:22 : _IsConnectedPhone Call
13:56:28 : _IsConnectedPhone(1)
13:56:28 : 0 - NotConnected.
13:56:28 : 1 - Normal connect success
13:56:28 : 2 - Emergency connect success
13:56:28 : Phone Mode(1)
13:56:28 : Call _ModeOffline()
13:56:29 : *****CheckPCSyncPrograms Start*****
13:56:29 : PCSyncPrograms Not Found
13:56:30 : CLGMobileHttp Class ?Ҹ????.
13:56:30 : CLGMobileHttp Class ?Ҹ?...
13:56:30 : ****************CheckAndDownload********************
13:56:30 : ******Extract Start LS670ZV9_20.S9_20.P60671.cab*****
13:56:30 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
13:56:30 : ExtractInfo Error(0)
13:56:30 : Extract cab file error.
13:56:30 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
13:56:30 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
13:56:31 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
13:56:31 : CLGMobileHttp Class ?Ҹ????.
13:56:31 : CLGMobileHttp Class ?Ҹ?...
13:56:31 : Page_Error ?κ??Դϴ?
13:56:31 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
What are you trying to accomplish? If you want ZVD, using the ZVD update thread in my signature is easier.
Please post output of:
c:
cd \KP500-Utils-EN-v0.4.2
dir
qhhjskh7788
