sfhub
Yes, you can revert to V9 or VC and get your hotspot back. Or you can upgrade to VD and TR1.8.2 and get your hotspot back.
I did it and it worked, thank you much ,however im not sure which recovery kernel i have.I used Z4 root. How to I install Xionia CWMA custom recovery or the stock V9. with the flash and root method you suggested?(a little link and post guidance would be greatly appreciated). Also google mail wont run now. keeps forcing closed
Here's what I observed:
When downloading from Marketplace, I get a call, 3G turns off and the downloads stall until I manually resume them after I hang up.
Is that a Rev-A symptom or something related to this new update?
Ok thread title updated, hopefully in a way that will get people to read the first post because:
1) Linked how to force flash an old version
2) Linked how to root if you want go that route
3) Suggested easy tether if you don't mind wired tethering and dont want to force flash or root your phone.
Just trying to keep the forums clean. Been merging threads about wireless tethering left and right lol
Ok, so I've tried using the method in the force flash link, and got as far as checking the output of the directory in step h. It says I should have 5 files, but I only have 2. I'm missing the 3 with the .dll extensions. It says if I don't have these 5 files, to stop and figure out why. I'm a newbie at this, and getting frustrated. Help!
